 CG on a Boomerang? >
CG on a Boomerang?
CG on a Boomerang?
Old 04-20-2008 | 12:56 AM
Default CG on a Boomerang?
I have purchased a Boomerang trainer from a friend who has misplaced the manual.
Anyone know what the CG should be?
Ray
Old 04-20-2008 | 02:07 AM
Default RE: CG on a Boomerang?
G'day Mate,
Start at the main wing spar, that is a safe point, & adjust as required after flying.
Boomerangs are not that critical, as far as balance point is concerned.
Old 04-20-2008 | 06:15 AM
No matter what the airplane, model or full size, if you have the need to "discover" the location of the CG range, get out your yardstick (for the model) and make 9 measurements. Plug them into this online application, and you'll have absolutely reliable information in about 10 minutes time:
http://www.geistware.com/rcmodeling/cg_super_calc.htm
Old 04-20-2008 | 11:49 AM
Thanks for the help.
I will start at the spar and have bookmarked the calc page.
My brother should maiden his boomerang on monday.
Another victim for the addiction
Old 04-20-2008 | 01:20 PM
What Boomerang, the only one I know of is the turbine trainer.
Old 04-21-2008 | 12:36 AM
If its a Seagull Boomerang 40 then the balance point from the manual is 7.5 cm - 8.5 cm from the leading edge.
Cheers
Old 04-21-2008 | 12:48 AM
ORIGINAL: Qld Flyer
Cheers
Thanks for the numbers,
Yes, it is the Seagull Boomerang 40.
RCU to the rescue!
