closing off a 3 line tank?
I have a 3 line tank...(vent, feed, fill) Just built a profile and only need 2 lines. (vent & feed) but, I have a 3rd.. (fill) dont need it... what is the best way to close off an unneeded line??? thank you thank you..
CA
I have a remote fuel system ( has the "dot" ) thought about running a short tube and use just the dot to plug it.. was hoping a drop of CA into the end of the tube might do it. Not sure if the fuel will eat it or not ?... thanks for the link.. I can just order another to replace mine.
AB, AUSTRALIA
Hi Panzerd18, how is things down south ? And no one mentioned solder but using ca which wont work either as the line is silicone and wont stick too good, but using a fuel dot will fix the problem .
Bill
Bill
Isn't there three pieces of alloy tube that pass through the clunk? Instead of attaching the silicon tube to the steel tube then plug the end I thought you could pull the silicon tube off and seal the alloy tube?
Nobody has mentioned epoxy, and for good reason.
If anyone considered any solution that uses epoxy, don't do it. Epoxy will break down if exposed continuously.
A very short bolt that fits the tubing works great. The size that would securely fit the inside diameter of the silicon tubing would be very light. And the threads insure a decent seal.
If I remember correctly, 4-40 works.
Hi!
Why not put that third line to the pressure nipple on the silencer so you have a Uni-flow tank!
This is the best tank set up using an ordinary R/C tank next to a Tettra "Bubbless" tank. Very few R/C modelers seems to know about this...!
Another option is replace the stopper.
http://www3.towerhobbies.com/cgi-bin...?&I=LXD756&P=7
