 engine for stinger 40 >
Old 05-04-2008 | 12:33 PM
Default engine for stinger 40
I have a Lanier Stinger 40 and I'm not sure what engine to put in it. I was thinking a Supertigre 51 or OS FS 52...
I'm told the thick wing will create a lot of drag and it needs more than a .46, what do you guys think?
Old 05-04-2008 | 03:24 PM
ChuckW's Avatar
Default RE: engine for stinger 40
If it were mine I would look at an OS .46-AX 2-stroke. This will provide excellent performance. whoever told you about the thick wing being a problem is mistaken. I've flown 40 size 3D/fun-fly planes with very thick, wide chord wings using a.46-AX and it was more than enough.
If you want to go with a 4 stroke, an OS .70, Saito .72/.82 or even the new OS .81 would work fine.
There are also less expensive engines similar to those I have listed. They may take a little more break in and there is an increased chance of getting a bad one but they will definitely get the job done too when running right.
What is your flying experience? I only ask because a Stinger is definitely not a good first plane and probably not even a good second plane.
Old 05-04-2008 | 07:27 PM
It's my third plane, I'll look at an .46 AX, thanks.
