Help setting up a SX600 radio.
TN
I have upgraded radios from a JR400 to a JR SX600. The Sx600 has servo travel adjustment that I can't seem to figure out. I have the low-rates set on 100% and the high-rates set on 125% and the travel is the same? Now, I am thinking that the servos are at there limits of travel but why is there the option to go above 100% if the servos will only go 100%? I need some more travel to get the recommended travel on my Pulse XT 60, I guess I need different servo horns. I would like to know what going above 100% travel does if it will not make the servos go any further though. Thanks!
MD
i've never used that radio, but you can down load the manual here. scroll down until you see the manual and click on the link http://www.horizonhobby.com/Products...dID=JSP16000**
