Binding
Hi all. I'm wondering what exactly binding is and its possible causes and fixes. I installed the servo control rod for my nose gear, and now the servo makes buzzing when I test it with the rudder control on the transmitter. Thanks.
IL
Is this with the plane sitting on the nose gear or with the nose lifted? If it's sitting stationary, there will be some binding as the nose gear is usually harder to rotate.
It's making this sort of buzzing noise even when lifted up...I guess it's binding. But It'd help if I knew exactly what it means to be "binding" and also its causes and fixes. Thanks all.
My Feedback: (10)
Binding means that something is rubbing somewhere a little too hard and cannot move freely. I would suggest diconnecting the nose gear and try the servo with rudder only. If it still happens, disconnect everything, still happens, servo might be bad. If not, figure out which push rod is rubbing and make it not rub.
