 Help with prop selection >
Old 06-03-2008 | 08:44 PM
My Feedback: (13)
Default Help with prop selection
I have a showtime 50 with a saito 91. Currently running a 15x4 prop. Would something else be better? According to the saito manual, props for aerobatics are in the pitch range of 9-10. This seems a bit fast to me. I thought it was all about thrust. Could someone please clear this up for me.
Old 06-03-2008 | 09:00 PM
Lomcevak Duck's Avatar
My Feedback: (14)
Default RE: Help with prop selection
That 15x4 should do fine. I run an APC 15x4 wide blade on my OS .91 four cycle. That long diameter and low pitch give great static thrust and it should be a good combo with that plane for 3D and vertical climbs. If you want a little more speed than the 15x4 gives you, try maybe a 14x6.
Old 06-03-2008 | 09:01 PM
My Feedback: (14)
In my experience, I've found that the manufacturer's prop recomendations are a fair starting point, but rarely right on.
