 Beginning in 3D flight >
Old 06-30-2008 | 09:36 PM
Default Beginning in 3D flight
I am not new to rc planes i am just new to 3d flying so i need some help on figuring out which plane( 3D ) i should get next.It has to be a reasonable size (nothing huge) and electric unless it is a small nitro powered plane. These are some of the ones i have been looking at.
- Fliton mini extra 260
- Fliton mini edge 540
- EFlite mini pulse xt (not sure if it is completely 3D)
- Or any of your suggestions
Are any of these planes good, bad, ect.
Thanks for any suggestions
Old 06-30-2008 | 11:05 PM
plugin's Avatar
Default RE: Beginning in 3D flight
U-Can-Do 3D is one of the best 3D trainers out there. I think there is a .40 glow.
Old 06-30-2008 | 11:12 PM
Nathan King's Avatar
ORIGINAL: plugin
I will preface this with the fact that I've never flown a U-Can-Do, but I have heard from a reputable source that a 40 sized glow engine is not enough to hover it.
Old 06-30-2008 | 11:30 PM
Yeah i have heard that also is a good plane but one of the main manuevers that i want to learn to do is hovering. But i will do more research on that plane but is there any comments on the above planes???
Old 06-30-2008 | 11:34 PM
would a 55ax be enough to hover good in a u can do 40 ?
Old 06-30-2008 | 11:51 PM
Jetdesign's Avatar
My Feedback: (8)
There are a bunch of UCD .40's at my club. Most of them have a Magnum .70 four stroke, one has a Magnum .91 four stroke, and one has a .46 two stroke (don't know brand). The two stroke is OK for easy flying, not for 3D, the .91 might be a little too much, but literally unlimited vertical.
People say really, really good things about that plane. It can float in without power from anywhere you can see it; lands very gently, flies easy, etc.
One guy says he wishes he got the .60 size. Most of them love the Magnum .70
Old 07-01-2008 | 12:31 AM
ChuckW's Avatar
You might want to ask the question in the 3D forum or the profile forum. 3D is a little advanced for a beginners discussion.
Having said that, get a 3D profile. Check out www.ohiomodelplanes.com or www.swanyshouse.com
The will outperform just about anything, you'll have an easier time doing it and they are tougher in my opinion.
Old 07-01-2008 | 06:59 AM
playntraffic's Avatar
I agree with Chuck. A profile is where you need to be with a 46-55 sized glow engine. They fly 3d much better than a full fuse because of the weight. The Mojo 40 would be excellent.
If you want to stay with Electric than the Funtana X Mini is a good choice. Why not start off with a foamy, dwfoamies.com? They are a lot of fun and are very durable when you flop one in from hovering low.
Old 07-01-2008 | 07:55 AM
Some electric suggestions are
Balsa
Extreme Flight - Extra, Yak or Edge
Precision Aerobatics - Extra 260, Katana or Addiction
Foam
Flash, Super Zoom or any of the MS Composit EPP's
Multiplex - Acromaster ot the Parkmaster which I'm not sure it's out there yet but is over here now.
The Fliton, I've looked at and considered them for a while and if I did get one would probably go for the Mini Edge but have heard quite a few comments on build quality / poor UC which has put me off.
Don't think the Mini Pulse is a 3D machine.
Personally I'd probably go for a foamie if it's a 1st 3D and probably the Acromaster as it's one of the toughest and will handle the most wind so can be an everyday flier although a number of people including myself seem to be suffering some motor mount vibration which can drive you nuts but think it's down to how well you glue the nose of the plane together on the build ansd the same with the motor mount as some don't suffer it at all, its' the one niggle on an otherwise excellent product.
Old 07-01-2008 | 12:50 PM
I definately will consider the u-can-do and put a larger engine on it, the acromaster, and i do like the extreme flight planes but they seem expensive and they do not seem like a "begginer 3D" but they do look cool . I did some research on the flitons and it seems that the mini edge 540 isnt very good, but the mini extra 260 got very good reviews and positive comments.
Thanks for all the suggestions
Old 07-01-2008 | 01:03 PM
Oh!!! i was looking at some edge 540s and i came across this one: http://www.raidentech.com/reded5402545.html
It looks cool but do you think it is any good?
Old 07-01-2008 | 01:35 PM
ORIGINAL: Big M
Flying brick. Those planes have been sold out at Raidentech and Nitroplanes for a long time.
Here is some helpful advice. Learn to fly 3D using a lightweight plane. Look for a large thick wing and a large wing surface to weight ratio.
Profiles are not the prettiest, but they are good at 3d training. They are more stable in almost all manuvers because of the low wing loading. You can overpower them so that you have more than 2 / 1 power ratio.
Old 07-01-2008 | 01:42 PM
Thanks for the info.
Old 07-01-2008 | 03:01 PM
how about a foamie like the Eflite extra or one of the great planes flatouts?
They are great for learning 3d on and can be flown at a baseball diamond or something.
Old 07-01-2008 | 03:03 PM
also inexpensive and easier to repair than a glow plane
Old 07-01-2008 | 03:18 PM
You should check out [link]http://www.3dhobbyshop.com/[/link]
Their name says it all
Rob
Old 07-01-2008 | 03:28 PM
I went on to 3d hobbyshop and i really like the katana and yak. Do those fly well for beginning 3D flying.
Fflier9, that e-flight looks like a good starter and i really like the size and the price!!!
Old 07-01-2008 | 05:56 PM
I have the 47" Extra 300 SHP so I am not sure of the flight characteristic's of the Katana and Yak but there are links at [link]http://3dhobbyshop.com[/link] that will take you to amother forum where the owner and a couple of the designers (that also happen to fly the full scale versions) hang out and can help you much better than I can
Rob
Old 07-01-2008 | 07:46 PM
I would like to get my next bird up and running without spending more than 300.00(is there a website with discount electrics), that is why i am starting to be attracted to the foamies(E-Flight Extra 260 3D Profile).
Old 07-02-2008 | 11:43 AM
hey Big M check this website out. If you really want to learn 3D on a budget you can look at these electronics.
http://www.hobbycity.com/hobbycity/s...&ParentCat=192
for BL motor/ESC combo
http://www.hobbycity.com/hobbycity/s...ec_Micro_Servo
for servos
http://www.hobbycity.com/hobbycity/s..._20C_Lipo_pack
for lipo
I have put together a great planes flatouts foamie
http://www3.towerhobbies.com/cgi-bin...outs&search=Go
with these exact products or less than $100 and it will do any 3D maneuver I ask of it.
Hope this helps.
Old 07-02-2008 | 11:44 AM
I dont know why the top 3 links wont work you just have to copy and paste them without the **** after the www. part
Old 07-06-2008 | 04:13 PM
That was a BIG help! Which do you think is better - the e-flight extra 260 or a great planes flatout(extra 300 or cap 580).
Thanks again for all the help!!!
Old 07-06-2008 | 05:04 PM
Missileman's Avatar
I have been real happy with my 90 size Hangar9 Showtime which is a great 3D plane and they do make a smaller electric version.
Old 07-07-2008 | 03:04 PM
I have heard that the park flyer gee bee 3D is a good starter so you might want to look at that plane. Has anyone else heard good things about this plane??? It comes RTF and ARF which is another advantage for a begginer.
Old 07-07-2008 | 08:33 PM
Big M
I would definitely say that the GP flatout series would be the better buy in your case
1. They are half the price, but virtually the same thing,
2. Replacement parts are cheaper (trust me, you're going to be making mistakes.)
Hope this helps.
