Electric Foamie Trainer
WA
Howdy!
I have 4 3s EVO25 2170 lipos and a JR 9303X Tx for my helis. I also have an AR600 Rx and some servos. I really want a slower flying foamie trainer. A PNP would be ideal.
Any recomendations?
Thanks!
T-bit
Any recomendations?
Thanks!
T-bit
RE: Electric Foamie Trainer
You intend to fly a transistor?
See http://www.rcuniverse.com/forum/m_7967880/tm.htm
What is a PNP? Is that a type of electric trainer aircraft?
Are you pretty competent with the heli's? If so, you might be able to get away with an intermediate plane like the Parksone T-28 or corsair. They aren't really trainers and I would never recommend them as a first aircraft but someone in your shoes might be able to pull it off. Both come in a plug & play version and can be pretty tame if you take it easy and use the lower control throws. Actually, even higher throws don't make either plane too difficult.
I have both and love them.
http://parkzone.com/Products/Default...ProdID=PKZ4675
http://parkzone.com/Products/Default...ProdID=PKZ4475
ORIGINAL: CGRetired
PNP is a Horizon Hobbies acronym for "plug-n-play". Basically the plane comes with everything except a receiver and/or battery. Basically you do some minor assembly, plug in your receiver and go fly. It's neat but 20 minute assembly times take some getting used to.
ORIGINAL: CGRetired
You and me be on the wrong siide of the Wheatstone Bridge. Old habits diode hard. ;-)
