 winterize >
winterize
winterize
Old 10-25-2008 | 11:13 AM
chemie's Avatar
Default winterize
I do not have after run oil and want to winterize for the season. In my garage I have
2 stroke oil
4 stroke oil
sewing machine oil
Which, if any, should I use instead?
Old 10-25-2008 | 11:15 AM
goirish's Avatar
Default RE: winterize
Hey you Michigander just keep flying and you don't have to winterize it. Can't be to cold in Midland.
Old 10-25-2008 | 11:19 AM
Non.Just go to walmart an get you some marval mystery oil. Its cheap an works great......Be sure to bring your batteries up. Don't let them set through the winter with low voltage
Old 10-25-2008 | 11:39 AM
XTOL's Avatar
ORIGINAL: chemie
2 stroke oil
4 stroke oil
sewing machine oil
Look in your garage again and see if you have a bottle
of automatic transmission fluid. (ATF)
One of the best after run oils you can get. Just dont use type "F".
It contains some kind of "friction enhancer" for certain types of
Ford transmissions.
Mike Hammer
Old 10-25-2008 | 11:51 AM
chemie's Avatar
NO ATF. Unless I go for a few drops from the dip stick from the car.....
Old 10-25-2008 | 12:43 PM
hogflyer's Avatar
ORIGINAL: chemie
Next time you're passing by Walmart or Autozone, just fork over the couple of bucks for a quart of Dextron III ATF. It a lot cheaper than bearings for an engine. I always keep a quart dedicated only to model aircraft use and keep it stored with the rest of my modeling supplies.
If you put the ATF from your transmission into your model engines, would you put the used oil from your car into your lawn mower too? [X(]
Hogflyer
Old 10-25-2008 | 03:14 PM
ORIGINAL: chemie
Come on. I live in Finland (home of Santa Claus) and I fly all year round. You can do it too.
Old 10-25-2008 | 05:17 PM
Villa's Avatar
Take offs and landings in the snow are terrific. A little lighter fluid into the carburator helps the engine get started. Thin gloves keep the fingers from falling off during a 6 minute flight.
Old 10-25-2008 | 09:48 PM
chemie's Avatar
I saw a video of a guy flying in a snow storm...he had Tx in a garbage bag...but that is not for me.
Old 10-25-2008 | 11:37 PM
Warbird Joe's Avatar
ORIGINAL: goirish
very good point IRISH. I agree with you 110 %. Keep flying.
Old 10-26-2008 | 12:03 AM
ORIGINAL: chemie
2 stroke oil
4 stroke oil
sewing machine oil
You didn't mention the fuel you've been using, no one can give you a definitive answer without knowing. So what's up? Morgan? Don't worry about it, just flush everything out next year. Castor? A gummed up carb takes 15 minutes to clean if it sits 20 years, don't sweat it. Name the fuel and at least 10,000 members (or more) of RCU can give you the answer.
Old 10-27-2008 | 03:54 PM
chemie's Avatar
OK. I bought a quart of ATF (DexIII) and poured about 1/2 a lid in the carb and down the glow hole and worked it in.
What do I have to do in the spring to get it back out?
(I am running 10% Coolpower).
Thanks.
Old 10-27-2008 | 04:45 PM
Winterize! Well that's just blasphemous! There's only one way to winterize, SKI'S
Old 10-27-2008 | 04:59 PM
carrellh's Avatar
If you put a lot of ATF in you can blow it out through the glow plug hole. Remove plug, cover hole with rag, spin engine with starter for a second or two.
Otherwise, start engine, leave glow driver on, rev engine to full throttle for a few seconds or until it stops smoking. Oil is gone and you can remove glow driver.
Old 10-27-2008 | 05:13 PM
goirish's Avatar
ORIGINAL: Stuntpilot51
Ski's or floats. Some of the best flying is in the winter.
Old 10-27-2008 | 07:01 PM
Chemi, I live just 2 miles into Ohio i mile off 127 and we fly year around. Your missing a lot of fun Herb
Old 10-27-2008 | 07:14 PM
goirish's Avatar
ORIGINAL: Herb Calvin
You are only about 40 miles from me. Go throught there on the way to Toledo. We normally take 20 to Toledo. Will have to go flying sometime.
