OS 40 FX Mixture screw,where is it ?? >
Old 06-01-2003 | 01:40 AM
Default OS 40 FX Mixture screw,where is it ??
Used to OS LA engines,an airbleed screw and a needle valve
simple.Just bought a OS 40 FX is the mixture control valve adjustment screw inside the throttle lever arm assembly ?
if thats it no where in their manual is this noted,OS's manual
is lacking!!!
Old 06-01-2003 | 02:37 AM
Not sure about the 40...but I would think it would be the same as the 46FX....in which yes, it is located inside the throttle lever barrel.
Mike
Old 06-01-2003 | 02:42 AM
Joe Ortiz's Avatar
My Feedback: (75)
Looking at my .40 FX book, mixture control screw is in the center of the throttle level.
Joe
Old 06-01-2003 | 02:45 AM
CP140's Avatar
Yep, that's it... the only "reference" (and that's really stretching the definition of the word "reference") as to where it is that I could find, is on p.34 of the manual.... you're right, the manual is just a little inadequate about indicating where it is....
