Balancing Jet Fan
Balancing Jet Fan
I added weight to the light fin. The fan seems to be stopping at different points each time. However, when I spin the fan with my electric drill, it vibrates. What am I doing wrong?!
Thank you.
Thank you.
KY
RE: Balancing Jet Fan
It is very possible that the drill shaft is bent, but don't let that take away from finding out if the blades are balanced properly. I have seen many bent drill shafts.
My Feedback: (16)
http://www3.towerhobbies.com/cgi-bin...&I=LXD712&P=ML
Rotating devices are often out of balance in two directions
You may need weight on a second fin in the same quadrant
