Zlin Z-50 Engine 46~52 - 56" Nitro Gas manual
hello , i need a manual airplane Zlin Z-50 Engine 46~52 - 56" Nitro Gas Radio Remote Controlled RC Airplane ARF ,I look for where it
KY
RE: Zlin Z-50 Engine 46~52 - 56" Nitro Gas manual
Did you get the model from Nitroplanes? If so, you will have to speak with them to get a manual. They have a support thread in the ARF forum which will probably yeild the quickest response. Good luck!
If it is from Nitro Planes, you might actually benefit from NOT having the manual. Some of the ones I have seen were so bad that they were useless. Seriously though, if you can't get them to respond or come up with a manual an experienced person at a local club could likely help you set the lane up correctly.
