2nd plane for OS Max .32SX
NC
Hi,
Looking for some advice. This is my RC experience: About 20 years ago I built and flew an electric high wing balsa kit successfully. Lost it when I went up late in the day and discovered that although it was visible at altitude, it was too dark to see the plane when landing and I put it into the top of a tall tree. The retrieval damaged it more than the crash and that was the end of that plane.
2 years ago I bought one of the Parkzone 2 channel electric planes, and found it more difficult to fly than the 3 channel version which I moved up to last year. I have had some fun with the 3 channel as it will do a loop, and unlike the 2 channel, it is possible to make low passes with the throttle full on. I also attempted several times from altitude to perform an outside loop, but the plane will not would not proceed past a vertical descent. One day the receiver (part of a circuit board in the plane) malfunctioned and I have not replaced it.
Last year my father-in-law gave me an OS Max .32SX, and all the related gear and electronics from a plane he had at one time. All that is needed is an airplane to put it in. I have 2 questions:
1. I am looking at the Phoenix Sonic .25, and am on the fence about whether my experience is adequate for the low wing version. I don't want to get bored too quickly, I think I could probably handle it if I put the control throws at their lowest setting initially. Yet I will be making a transition to glow at the same time. And honestly, I am going to do the same thing I have done with the other planes: Go out to a field near my home, all by my lonesome, and fly it. High or low?
2. Having no glow experience, I am uncertain about the realistic applications for this engine. Am I limiting the choices too much by looking only at .25 options?
RE: 2nd plane for OS Max .32SX
You are a long way off in what your prior experiance is and trying to make the conversion to much faster flying airplanes and airplanes that will require quite a bit more room than what you think. This is worse since you are going to do it the expensive way in terms of wreacked airplanes, You need to stick to a true 25 sized glow trainer such as the Sig LT-25. Doing anything else in terms of more advanced types is only fooling yourself and going to make a bigger impression on your bank account.
http://www3.towerhobbies.com/cgi-bin...?&I=LXFG17&P=7
John
John
NC
Your advice is well taken, but I point out that the high wing Phoenix Sonic is billed as a .25-.32 trainer, just as is the Kadet you suggest. Both have a flat bottom airfoil. When using the research section of this website in looking at the Sonic, it is referenced as a trainer. What is the difference?
PA
The high wing Sonic would probably be a good trainer. The OS 32 SX will probably make it a screamer, so be sure to exercise some throttle control when you first start out.
