 First Plane OOOPS!! >
First Plane OOOPS!!
First Plane OOOPS!!
Old 12-24-2008 | 07:47 PM
jmwright75's Avatar
Default First Plane OOOPS!!
I am building my first plane, and had an oops. I am building the GP PT-40 and when I glued the fuse doubler in I didnt notice at the time but it is glued to far down. Now that I am getting ready to put the front fuse bottom and rear fuse bottom in the notches are covered and there is no recess for them to fit in. Am I S.O.L. or can I carefully cut away a bit of the doubler and still be good? Any input would be greatly appreciated.
Old 12-24-2008 | 08:00 PM
w8ye's Avatar
My Feedback: (16)
Default RE: First Plane OOOPS!!
Study it all carefully and cut away the interfering parts
Old 12-24-2008 | 08:04 PM
jmwright75's Avatar
Thank you for the input W8ye just needed to be sure i wouldnt mess it up even more.[X(]
Old 12-24-2008 | 10:06 PM
w8ye's Avatar
My Feedback: (16)
As long as you have nut made to left hand pieces you're probably OK
If you need to remove some doubler in some areas - you want to add some doubler in other areas where part of the doubler is missing. Just use scrap wood.
The best model builder is one that can recover from a mess up.
Old 12-24-2008 | 11:27 PM
ChuckW's Avatar
You'd be amazed and probably amused if you could see some of the mistakes that I've made then had to somehow make work.
