 Super Glue in leu of Thread Lock???! >
Old 12-25-2008 | 10:31 AM
Default Super Glue in leu of Thread Lock???!
Hey guys, In a pinch can I use super glue or silicone glue on botl threads to help lock them in?
I'm using it for the engine mount on a trainer plane. It is a metal bolt, that goes through the wood (firewall) and into a metal nut that is attached to the fuselage
thanks!
Tim
Old 12-25-2008 | 10:39 AM
Jetdesign's Avatar
My Feedback: (8)
Default RE: Super Glue in leu of Thread Lock???!
I've used epoxy and it worked fine (and was able to remove bolts when needed). Not sure about super glue.
Old 12-25-2008 | 10:45 AM
The instructions on my World Models LA Racer (sport plane) which is my first gas plane say to use threadlock or CA so I would think you are fine.
Old 12-25-2008 | 11:31 AM
My Feedback: (-1)
Yes, thread lock is better but in a pinch I have used them both and gotten away with it.
Old 12-25-2008 | 11:50 AM
Before Loc-tite it was common to use fingenail polish on the threads just before screwing in. I never had any trouble removing a bolt later.
Clay
Old 12-25-2008 | 03:21 PM
I use gel super glue as a thread lock alot
Old 12-27-2008 | 07:02 PM
My Feedback: (209)
I have tried thread lock, tightbond, , blue in color when applied, and the next day it's still wet! I won't use it again, waste of money.
All I do is use gap filling CA, just a drop, done deal. Hit it with accelerater, good to go.
