 Engine Rich or Lean??? >
Old 01-10-2009 | 09:01 PM
My Feedback: (17)
Default Engine Rich or Lean???
I just got a Iron Bay Regulator for my Saito 125, the manual just calls for you too richen the HSN 2 turns out than normal. Then you can go ahead and tune as normal. So I did my normal tuning procedures, I leaned HSN until I reached peak RPM then richened until I dropped about 800 RPM. Flying around at about half throttle I have a nice steady smoke stream from the exhaust but as soon as I open to full throttle the smoke disappears. Does this mean anything??
Old 01-10-2009 | 09:07 PM
Default RE: Engine Rich or Lean???
It might mean the LSN is set to rich.
Old 01-10-2009 | 09:08 PM
w8ye's Avatar
My Feedback: (16)
If the engine runs good and has good power I wouldn't worry about it
Old 01-10-2009 | 09:10 PM
w8ye's Avatar
My Feedback: (16)
ORIGINAL: chashint
Did you ever adjust your low speed mixture as Charlie has mentioned?
Old 01-10-2009 | 09:28 PM
My Feedback: (17)
Charles?? Gray Beard?
Old 01-10-2009 | 09:29 PM
My Feedback: (17)
ORIGINAL: chashint
I didn't think the LSN would have any effect on anything besides idle.
Old 01-10-2009 | 09:37 PM
w8ye's Avatar
My Feedback: (16)
It could cause the smoke you see at the lower speeds
Old 01-10-2009 | 09:56 PM
FILE IFR 's Avatar
On the ground and at a low idle (while secured), what happens when you go to full power quickly... cough, burble, excess smoke or die?
Does it go to full power instantly with no 'ramp-up' in speed??
Again on the ground From full power to idle, when AFTER the stick is brought to idle will the engine speed be the same or slowly sag???
Old 01-11-2009 | 11:13 AM
ORIGINAL: FILE IFR
This is the test you should use. Smoke from idle is usually common in the air.
Old 01-11-2009 | 11:16 AM
ORIGINAL: FILE IFR
This is the test you should use. Smoke from idle is usually common in the air.[quote]ORIGINAL: FILE IFR
