What type of Starter? >
Old 03-22-2002 | 04:24 AM
Default What type of Starter?
What type of starter do you guys use in your flightbox?
And do you use one with a rechargeable NiCad pack? Or do you plug it into your power panel on your box?
The reason I'm asking is that I don't have one yet, I'm doing the chicken stick thing, and am about ready to move on up.
Currently I'm working with 40 sized 2 strokes if it makes any difference.
Old 03-22-2002 | 04:52 AM
magnum's Avatar
I you are planning to stay in the .40 size engine range then get a Sullivan Hi-torque starter. Will turn it over nice. If you think you might like to go to bigger engines later, get a Magnum.
I went to the local battery store and found a 17A 12V closed cell battery for $45. Works great. The 6A gel cells are ok, but they loose power to fast.
Old 03-22-2002 | 01:48 PM
Dansy's Avatar
My Feedback: (53)
I'm using the Kavan gear starter with a nicad pack of 2400 mah, good enough for my OS 140.
Daniel D.
Old 03-22-2002 | 03:17 PM
Default Starter
I have a Tower starter that I run through my power panel. I've had the starter for about ten years now and it's still starting .
Old 03-22-2002 | 03:52 PM
I originally had one that plugged into my power panel and quickly found it to be a pain in the rear. Whatever brand of starter you get (Sullivan, Hobico, Tower, etc.) I would definately invest in a portable power pack.
Kent
