Wind?
Hard to put an exact wind speed number on it. It actually does pretty good in winds so long as you aren't talking about tornadoes or hurricanes. Just keep a little throttle on when landing and it'll be fine. The biggest problem on windy days is on the ground; the wind can get under the wing and flip it over.
The little T-28 does surprisingly well in winds. It is fast enough to be able to overcome a decent wind and is actually a good way to work on those windy day skills since it is a challenge you can just buy new pieces or glue it back together if you crack it up. It will definitely flip over on the ground though.
