Loss of signal to an AR500
NE
I purchased a DX7 this February and installed an AR500 in an Easy Sport. I flew it last week with no apparent problems. Yesterday, I flew it for about 10 minutes and brought it down. After I landed the plane, I couldn't turn it to come back to me. I thought I had killed the engine so started to go get it. As I started to walk to the plane, I goosed the throttle and the engine revved up. I was able to bring it back to me. I didn't think much about it and took my plane back to the pits. I fueled it up and later on took it back up again. This time I flew if for a few minutes when I lost control. Fortunately I was climbing after a turn so the plane was not headed towards the ground. I didn't panic and was able to gain control again and land it. After I landed the second time, I realized I had lost control after landing in the prior flight.
I have the receiver mounted on a pop cycle stick via velcro with a zip tie wrapped around it, I have the long antenna strung along the fuse in a shrink wrap tube. How can I tell if it is the transmitter or receiver that lost control? We range checked it and didn't have any problems. I suppose the safest thing to do would be send the receiver in to be checked.
NE
RE: Loss of signal to an AR500
I knew I forgot to mention something. The first thing I did after I brought it in the second time was to take a voltage reading to see if there was an obvious reason the receiver glitched. The voltage was around 5.1 volts on a 4.8 battery.
ON, CANADA
I agree with jollycub, Test battery voltage under load. The ar500 will failsafe under 3.5 volts...maybe abit more.
If problem presist after battey is fully charged then call spektrum help line
NE
Thanks for the input. I'm afraid I shut it off at the runway, then checked the battery. Next time I will leave it on to check the light. Great tip!!!
NE
Are you talking about using the wattmeter with an electric? I was flying a glow engine albiet implied (thought I killed the engine...fueled it up etc.) The voltage protector in the picture looks like a capacitor.
Yeah, it does look like a capacitor, a large one, which would make sense.
Just for your information, and to add to your wealth of information, Capacitors tend to keep voltage constant by discharging as the voltage drops below the threshold, but it the threshold is what the battery is currently charged to. What this means is when the power is turned on, the capacitor will charge up to the supply voltage. When the system draw brings the voltage down (which happens when you move servos), if the voltage drops lower than the threshold which it is charged to, it will begin to discharge which tends to keep the voltage at the threshold point (note.. not the re-boot threshold point, but to the point where it was charged to, which is the nominal battery voltage).
CGr.
CGr.
Hi!
A capacitor (which the above picture shows ) isn't needed on the recent Spektrum receivers!
Always bind the receiver and transmitter when all trim settings has been finally done!!!!
That capacitor device was designed to filter out noise generated by electric motors. This has been repeatedly stated by Danny Snyder, the JR rep.
ORIGINAL: jollycub
