glue
Old 04-19-2009 | 05:36 AM
wzak29's Avatar
Default glue
Was thinking of using this glue on my next plane http://www3.towerhobbies.com/cgi-bin...?&I=LXK311&P=7 on my last build I found CA dries so fast I can’t properly align things.
Old 04-19-2009 | 05:56 AM
Default RE: glue
The following is about using thin CA. When I am using Thin CA, I align the parts and then apply the adhesive. The CA will wick into the joint and bond the parts together perfectly. I see people state what you have said, and have wondered if they understand how to use this product. A perfect example of how I use CA is when assembling a wing panel. Assemble the ribs onto tha spars and add the leading edge(s) and trailing edges. When all is aligned, drip a single drop of CA onto every joint and your done. Thin CA isn't always the right tool for the job.
The alphatic Resin Glue you've linked to at Tower Hobbies, is a fine glue type. It is also available at your local hardware store as Elmer's or Titebond and may be cheaper there. I use Alpatic Resin and the poly glues also. Alphatic resin should not be exposed to moisture.
Good Luck
Old 04-19-2009 | 08:49 AM
Default RE: glue
I use [link=http://www.dickblick.com/products/elmers-glue-all/]Elmer's Glue-All[/link] white glue which can be found in any hardware or drug store. But I still use CA where I need a quick drying glue. Wood glue such as the one you linked dries yellow as the Elmer's dries clear, which I like alot.
Old 04-19-2009 | 09:05 AM
DavidAgar's Avatar
My Feedback: (108)
Default RE: glue
I use the thick CA from Bob Smith. It allows you a few seconds of adjusting your wood if you need to. The glue you have linked is also great stuff. I use it for gluing doublers and sheeting or any other large surface. Good Luck, Dave
Old 04-19-2009 | 09:13 AM
Alex7403's Avatar
Default RE: glue
i use titebond 2 it dries orange and i like it shows where i didnt forget to glue.
i buy it at sears or other hardware stores.
