 engine mount for Saito 72 >
Old 05-26-2009 | 10:19 PM
Default engine mount for Saito 72
This may not be the correct forum to ask this question but does anyone know if it would be ok to mount a Saito 72 on this mount? <span class="Apple-style-span" style="font-family: 'Lucida Grande'; white-space: pre; ">http://www3.towerhobbies.com/cgi-bin...XJ772&amp;P=ML
<br type="_moz" /></span><br type="_moz" />
Old 05-26-2009 | 10:33 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: engine mount for Saito 72
It should be fine on that mount</p>
Ken</p>
Old 05-26-2009 | 10:43 PM
jimmyjames213's Avatar
if i can put a .91 magnum 4 stroke on that mount you can put a saito .72 on that mount
Old 05-27-2009 | 07:32 AM
I have a Saito 82 on that same mount. Works great.
Bob
Old 05-27-2009 | 09:16 AM
Pete737's Avatar
Saito 82. If you through bolt, Don't tighten down too much or the bolts will bend.
Pete
Old 05-27-2009 | 10:29 AM
ChuckW's Avatar
Just drill and tap the GPmount. The plastic threads great and holds very well.
Old 05-27-2009 | 12:18 PM
Thanks guys... The engine looked kinda big sitting on that little mount, but if it's working you I'll give her a try!
Old 05-27-2009 | 12:41 PM
Good Luck,
Here's my 82 on a 40 size Stik
Bob
Old 05-27-2009 | 01:05 PM
That's exactly what this .72 is going on! What is that round plastic thing behind the wing?
Edited to include:
By the way, what a great airplane! I had mine out yesterday (with it's 46 AX). There were big white cumulus clowds towering up with blue sky in between. The Big Stick looked great rocketing straight up with those clouds in the background! I would have taken a picture but I was by myself. I was having fun doing full power low speed passes then at the end of the runway turn it straight up as high as I can still see it, and then chop the throttle back to idle and dive straight back down and down the runway in the other direction, still at idle, but with the energy from the dive. At one point I wanted to see if I could land it that way... No problem! The thing slows down so good I was going from about a 400 foot power off dive straight in for a landing! No flaps, no crow, just that big fat wing slowing things down! Too much fun. I like discovering new things it can do.
Old 05-27-2009 | 01:16 PM
It houses my Switch. Keeps the fuel residue from the switch.
I Should have mounted switch on the left side of the fuse.
Bob
