 questions about CA hinges >
Old 06-02-2009 | 11:38 AM
Default questions about CA hinges
Hi guys. Ijust rebuilt the tail on my uproar, Iran out of balsa so i used a old yard stick Ihad laying to make the TE. My question is, Icut the slots for the new hinges, will CA hinges glue into the yard stick and hold? I know the yard stick is a harder wood then balsa so Iwas'nt sure it they would hold.
Old 06-02-2009 | 11:44 AM
MinnFlyer's Avatar
Default RE: questions about CA hinges
As long as it's a snug fit, it'll work fine
Old 06-02-2009 | 11:52 AM
thanks minnflyer. Iwas hopeing it would work.
Old 06-04-2009 | 09:32 PM
I wouldn't trust it without using the thick CA which would form a reasonable joint not reliant upon the CA being absorbed into wood as it d oes with balsa
Old 06-04-2009 | 09:45 PM
MinnFlyer's Avatar
AAAARRRRRRRRRGGGGGGGGGGHHHHHHH!!!!!!!!!!!!!!!!!!!! !!!!!!!!
NOOOOOOOOOOO
<font size="4">NEVER </font>use <font size="4">ANYTHING</font> but <font size="4">THIN CA</font> on CA hinges!
Old 06-04-2009 | 09:52 PM
CGRetired's Avatar
The whole thing with CA hinges is that the CA has to wick... soak into.. the hinge as well as the wood it is inserted  into.  This makes the bond between the hinge and the wood.  If you use thick CA, it will NOT flow into the slot and get to both the hinge and the wood.  IT HAS TO FLOW into the slot.  Thick CA will not do that.,  It will just settle at the base of the hinge and not soak, or wick in.
CGr
Old 06-04-2009 | 09:56 PM
jrcaster's Avatar
I agree, don't use anything except thin CA.  Also since the wood is harder, it will take longer to harden.
Old 06-05-2009 | 09:22 AM
Thanks guys, It did work, but it took a little longer to set. Ithought it was'nt going to work, took longer then it normally does with balsa. but them seem solid now. Thanks again. Oh Yea. Iused thin CA. Ialways use thin on CA hinges.
