 Filling drill hole in balsa block >
Old 07-07-2009 | 04:59 AM
timrob's Avatar
Default Filling drill hole in balsa block
Hi, a quick question. What is the best way to fill a drill hole in a balsa block, so you can re-drill it (e.g. if doing hinges).
Tim.
Old 07-07-2009 | 05:27 AM
CGRetired's Avatar
Default RE: Filling drill hole in balsa block
CA it and move the hinge slot over to the left or right (up or down if rudder).
Old 07-07-2009 | 05:30 AM
Korps's Avatar
CA works wonders. Can't believe I went so long in my life without knowing it :P
Old 07-07-2009 | 06:41 AM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Use a wooden dowl rod to fill the hole. Glue it into the hole, cut if off flush with the surface, and then redrill the hole you need.
Ken
Old 07-07-2009 | 07:25 AM
I agree with Ken, i use toothpicks when the hole allows or a piece of dowel.
Old 07-07-2009 | 08:06 AM
Live Wire's Avatar
Balsa stick and wood glue.
CA will have you drilling holes all over the plane and never where you want it, Harder than the wood you want to drill. Just as much off as you were to start with[:@]
Old 07-07-2009 | 10:31 AM
timrob's Avatar
Thanks everyone.
Tim
