 Will this cause a problem? >
Old 07-08-2009 | 06:42 PM
brett65's Avatar
My Feedback: (18)
Default Will this cause a problem?
You can see in the pic that the rudder is bowed/arched just a bit. Other than having to adjust the trim for it and causing a bit of drag, will it cause any major problems?
Old 07-08-2009 | 06:50 PM
mclina's Avatar
Default RE: Will this cause a problem?
I've got planes way crookeder than that. Go for it.
Old 07-08-2009 | 06:58 PM
MinnFlyer's Avatar
No problem
Old 07-08-2009 | 07:07 PM
bonebreak's Avatar
I want to see the WHOLE plane Brett!
Old 07-08-2009 | 07:44 PM
ChuckW's Avatar
I have a Yak with a rudder trailing edge with multiple bows. I tried getting them out by pulling and re-shrinking the covering nut finally gave up. It's not perfect but flies fine.
Old 07-08-2009 | 09:28 PM
you'll be absolutely fine I've flown planes all crooked and bent up haha
Old 07-08-2009 | 09:30 PM
-pkh-'s Avatar
Just trim it out in the air, you should be fine!
Old 07-08-2009 | 11:38 PM
brett65's Avatar
My Feedback: (18)
ORIGINAL: bonebreak
Patience, patience.
I just completed the wing tonight, my first ever flap and retract set up. The door setup isn't the greatest on this thing, the wing is curved and the doors are flat.[>:]
Old 07-08-2009 | 11:44 PM
sportrider_fz6's Avatar
I've got planes worse then that, once you get it trimmed out it will be fine
Old 07-09-2009 | 01:34 AM
Looks like about 2 clicks of right rudder trim and you would be good to go. Good luck!
Old 07-09-2009 | 07:48 AM
Brett,
Is that an Airbus rudder ? jk,
Trim it in flight, should be fine.
Bob
