 Engine Test Stand? >
Engine Test Stand?
Engine Test Stand?
Old 01-13-2010 | 09:42 AM
Bonified Wingnut's Avatar
Default RE: Engine Test Stand?
Here's the last one I threw together for a Fuji BT 24 EI.. The cat is for reference.
ID:	1355294   Click image for larger version
Old 01-13-2010 | 02:07 PM
Mr67Stang's Avatar
ORIGINAL: combatpigg
What's wrong with running it in the model?
If it was a 2 row, 18 cylinder radial, then ya you betcha...run it on a stand after a rebuild.
C'mon CP, I have more engines than I have planes. So before I buy another plane, I want to verify the crusty castor blocked engine will run
