 4 stroke Break in and Castor Oil >
Old 08-26-2009 | 09:16 PM
My Feedback: (14)
Default 4 stroke Break in and Castor Oil
This may be a silly question but here goes:
I'm fairly used to 2-stroke engines and am finallly getting into using 4-strokers.
Got my first recently, a Magnum XLS 52 and want to do a good break in.
Manual recommends fuel with 10% nitro and at least 20% castor oil. Best I could find at the
LHS was a 10% nitro with castor/synthetic blend fuel. I bought some castor oil from the LHS
as well and was intending on adding some castor to the fuel. Question I have is how much
castor to add for a gallon of fuel of this type that won't impede engine performance.
Thanks for any opinions!
Old 08-26-2009 | 09:20 PM
Default RE: 4 stroke Break in and Castor Oil
i believe 2 1/2 oz of caster will bring it up 2%, or thats the formual i used to break my magnum 52 fs in
Old 08-26-2009 | 09:38 PM
My Feedback: (20)
mj, Global, the distributors of the Magnums have stated that the 20% castor is an old recommendation made when synthetics weren't as good as they are these days, your off the shelf Castor/Synthetic blend will be fine as long as it's a good brand. Some people don't advise using "full" Castor in 4 strokes because they say it can clog your valves (it doesn't burn). I use full synthetic in my Saito's and they run like a swiss watch.
Taken from Global's FAQ forum
Four-Stroke Engines
These recommendations work well for both break-in and normal running after break-in.
.30 Use 15% ~ 20% Nitro Methane Fuel with 18% ~ 20% Castor Oil/Synthetic Oil Blend Lubricant
.52 and Up use 15% ~ 20% Nitro Methane Fuel with 16% ~ 18% Castor Oil/Synthetic Oil Blend Lubricant
Old 08-26-2009 | 10:05 PM
Charlie P.'s Avatar
RGM762 has it. 128 ounces to the gallon. If the gallon is 18% castor oil to begin with you'll need to add approximately 128*.02 or a hair over 2-1/2 ounces. Course then you have a 130-1/2 oz of fuel so the nitro will be only 9.8%
Old 08-27-2009 | 03:29 PM
My Feedback: (14)
Thanks for the input all!
Old 08-27-2009 | 03:33 PM
opjose's Avatar
As Cold_Reboot said: "fugett-about-it!".
It is not needed and is an old recommendation.
I broke my first Magnum in with a castor mix and all my subsequent ones with Cool Power Synth.
No problems what-so-ever with this.
