electric prop on a glow engine?
i wouldnt try it....They are less rigid, and may not stand up to the vibration of a glow/gas engine. Allthough you can use a glow/gas prop on an electric, you probably wont get the same performance as an electric prop
They are much thinner and lighter and they aren't intended to handle the vibration from a glow engine. I would not use a prop specified for electric on a glow or gas engine due to a possible risk of failure.
