 OS 61FX break-in? >
OS 61FX break-in?
OS 61FX break-in?
Old 12-02-2009 | 07:36 PM
Default OS 61FX break-in?
What is the best way to break in an engine? In the book it talks about the 10 seconds rich, 10 seconds lean.....do i leave the engine running full throttle The whole time? My local hobby guy said that he suggested leaving the hsn set rich, and going back and forth from idle to 1/2 throttle for the first tank. What do you all suggest?
Old 12-02-2009 | 07:49 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: OS 61FX break-in?
Your best bet is to follow the instructions in the manual. They print that in the manual for a reason. For the 61 FX I've used the method in the manual and I've got engines that run with no issues at all.
Ken
Old 12-02-2009 | 09:26 PM
jimmyjames213's Avatar
i bolt my engines on my plane and have at it, no breakin on the bench. what i do is keep the low end very rich and the high end rich, but lean enough where it will clear out.
then i fly it just above the point where the engine doesnt load up for a min or so (usually a little above half throttle) , then lower the throttle and let it cool off/load up, then i advance to the point where it clears out and alternate till its time to land. i do that for a few tanks with a small prop for 2 strokes (11x7 for a .61),
so far i havnt had any problem doing that, and its more fun than watching a engine spin on a bench (which is still fun )
just keep the plane close incase of a flame out, which if you listen to the engine, it is really easy to tell when the engine is loading up/dieing.
if you want to break it in on the bench, use the above method only keep it on the ground.
Old 12-02-2009 | 09:48 PM
oldvet70's Avatar
My Feedback: (10)
RCKEN is right. Follow the manual and you will break the engine properly with ease.
Old 12-02-2009 | 11:18 PM
ORIGINAL: AnAlternateEgo
Yes, at full throttle, adjust the needle until you get the highest rpm and let'er rip for 10, then richen and go for 10, etc etc etc. The last couple of mine were good to go after a couple of tanks of cycling like that.
As for the LHS suggestion, don't waste the gas, 'cause that won't do much at all. Unless the engine gets to operating temperature no real breakin happens, and running rich doesn't do get near breakin temps. The 10 second cycle is an excellent way to control the heat cycling.
Old 12-03-2009 | 12:07 AM
proptop's Avatar
My Feedback: (8)
I guess Dar doesn't visit the Beginners forum very often...
Old 12-03-2009 | 07:48 AM
downunder's Avatar
ORIGINAL: proptop
He's busy writing up HIS method for running in electric motors .
Old 12-03-2009 | 09:02 AM
Well, if it's a super tigre engine run about 2 gallons of fuel through it.
If it's an O.S. engine run about 1 tank of fuel through it!
Either engine, never run them too lean!
