how to dry fuel from balsa?
I was breaking in my engine on the plaen and then Iflipped it over, Iopen the carburator and guess what? Irealized that the inner side of the cowl wasn't fuel proof... the carburator spat a pretty amount of fuel on it.
I'm thinking on use some epoxy thinned with alcohol but I believe Ineed to take that fuel off the wood first...
Is it just the cowl? And I would have to assume that it is a wooden cowl. And does the cowl come off?
If so, remove the cowl and give it a good dousing with denatured alcohol. I would give it at least 3 applications.
You could also dump in some cornstarch between applications to soak out the oil as the alcohol dries
nope, it is the upper part of the cowling on the top flite P51... it doesn't come off. but still Ican put some alcohol and cornstarch Iguess.
MO
Acetone will desolve ca glue. The previous methods alcohol/cornstarch or KR2 are fine.
Then there is the SYLVESTER approach (bury it in cat liter) We HIGHLY recomend the fresh stuff though.
It actually absorbs the oil very well.
Iused the alcohol method and it worked fine, Ialready coated the whole thing with thinned epoxy. Istill can't figure out why they didn't did so at the factory...
