 Super Tigre Engines >
Super Tigre Engines
Super Tigre Engines
Old 02-11-2010 | 12:21 PM
ChuckW's Avatar
Default RE: Super Tigre Engines
Agreed. I found that the OS #8's and A3's made a noticeable improvement in my Super Tigre engines over the ST plug. Then I just decided to buy the OS engines.
Old 02-11-2010 | 12:36 PM
opjose's Avatar
ORIGINAL: Bax
Point of note......You can use any O.S. glowplug that suits your needs. We tend to use the O.S. #6 (old A3) or #8 glowplugs with no problems. In fact, we believe that the O.S. #8 glowplug is just about the best general-purpose glow plug you can use. With low-nitro fuels (0% or 5%), the #6 is a good one to try. We use O.S. plugs all the time and strongly recommend them.
Are you not recommending your own plug?
Old 02-11-2010 | 01:24 PM
Mr67Stang's Avatar
ORIGINAL: opjose
ORIGINAL: Bax
Bax is the moderator for the OS engines forum. So, yes he is recomending "his own plug"
However, I agree with him
Old 02-11-2010 | 03:34 PM
opjose's Avatar
I would assume so!
I would also assume there is a reason for the longer plugs used on the SuperTigre, Tower Hobbies, and other engines manufactured ( supposedly ) in the same plant.
In practice, the longer plug keeps the coil out of any fuel pooling, especially with an inverted mount engine.
Substituting the shorter O.S. plug removes this advantage.
