Custom Field Boxes
MO
ORIGINAL: Deadeye
I made this out of coroplast. Cheap, light, strong, chemical and water resistant. Battery and fuel pod separate from the main box, and attach to each other.
How many crashed spads did it take to make the box?
I like corro for such things. I made a nice 24" x 24" x 48" 12 bay balsa bin out of "LEFT WING" coroplast. THANK YOU TO THE DISTINGUISHED SENATOR FROM MO.[>:]
1 Post
ORIGINAL: bbrown2828
Ok well i have finshed it... now it has a new set of banna plug ports that will sever as a charge port when the box needs charging and also it will server as a exter 12v to plug in my field charger.... then Ihave a master switch that i can kill all power to the panel while chargeing and also put in a volt meter to check voltage here are the new pics
lol
