My rolling hanger
Just finished upgrading my trailer and wanted to share some photos.
As I have said on other posts, I don't have room for planes in my home or garage so they must all fit in the trailer, so what you see is what I have.
All supplies and tools [big tool box was not in place when photo was taken] are in box on the left side and my radio is in the blue plastic container just in front of the battery box.
Gary
Gary
ORIGINAL: RCKen
Roo Man,
Only one problem with it. Too much empty space. You've got room for a lot more airplanes in there!!!! Time to start filling that wasted space!!!
</p>
</p>
Ken</p>
Roo Man,
</p></p>
Ken</p>
I can barely keep up with 4, as you see the SSE [w/o engine] is still in rebuild, just finished rebuild on the UCD. Also the one thing there is not enough of is the green stuff.
Gary
My Feedback: (76)
Man thats nice Iwish i had a rolling hanger but i will have to settel with my Hanger in my garge and then my pvc transportation rack in the back of my truck to carry three planes to the field i dont know what i am going to do when i go bigger than 40 and 60 size planes guess i will have to break down and buy a trailer weather the wifey likes it or not but i did just get my work bench in my garge done i am glad that i know have a place to work on my planes here are some pics
I had to get in to this thread. When I started flying I knew I was going to need one. So last year when my cousin gave me a boat trailer I started building onto it. It is a constantly on going project that has been modified a few times since I started. I tried to keep the weight down as much as possible and seems to have worked out well. I have about $600.00 or $700.00 into it- including plates and a spare tire. I learned a few things in the process. It aint fancy but I can't complain because now I can take everthing I need with me and I have room in my house again. It is 12' long, 6' wide, and has a 5' ceiling. It is light enogh that I can pick one side off the ground with no problem. I pulls very easy.
I don't even own a car..or a truck, but I have somebody tow the trailer to the field and I am all set.-BW
ORIGINAL: Bonified Wingnut
Gary
I picked the blue because it was the same color as the tarp I had over it while I was building it. When I went to buy paint I grabbed a tarp and told them to match it. I see other people rebuilding pop up campers for trailers. It is a temporary solution. I am hoping to pick up an aluminum one about the same size. If the one I have is still in anykind of shape I will probably just give it to another modeler in need.-BW
This is my what I called it hobby center trailer. it took me a lot of efforts and upgrades to build it so what do you think let me know what else i can add
at field
loaded with 3 airplanes
fuel tanks with 3 pumps for different type of fuel gas or glow
tools drawers
and get started
at field
tools drawers
and get started
ORIGINAL: sportman
That beautiful Sportsman. Are those decals on the side? If they are where did you get them?-BW
IA
I am in the middle of stripping down a old pop up camper for my Trailer..For some reason my 30% Giles would not fit in my Jeep. Quess I have to build a trailor.. Hate when that happens...LOL
I like to
To have all the needed stuff with me ever time I go to fly so I build it, my fuel, my tools and airplanes are in place also I do not have to think and care to recharge the main battery because it recharging while towing and connected to the towing car,m the only thing I would like to and is poertible wind sock to know the direction of the wind..it's in order..many time we flew in open desert not in proper fly field..it's ver remote area..so get everything and anything you need is necessary
ORIGINAL: dmesecher
Nice trailer. though you need some paint job and renewing it. your planes needs to be secured on stand with tension rubber belt like I did) otherwise during the transportation may moved and be broken
WY
ORIGINAL: sportman
That looks like an old horse trailer. Cool idea, but I would think it would be stained with horse fecal. That would not be fun to clean out or paint over. Probably wouldnt smell pleasent either. Did you have any problems with that?
