 stupid prop question >
Old 04-21-2010 | 09:13 PM
Default stupid prop question
Is there a propper way to put on a prop to minimize vibration, I mean with it at 1 oclock with the engine at the compresion stroke...or can you just screw it on anyway lol
Old 04-21-2010 | 09:38 PM
w8ye's Avatar
My Feedback: (16)
Default RE: stupid prop question
There's a slim chance that it will run smoother in a certain position
I always just make them horizontal when coming up on the compression stroke
Old 04-21-2010 | 10:18 PM
My Feedback: (13)
I make them horizontal on the compression stroke. I figure they stay out of the way during a possible dead stick landing that way.
Old 04-21-2010 | 10:24 PM
opjose's Avatar
On one gasser, I noticed that vibrations were reduced GREATLY when the cylinder was at TDC with the prop horizontal to the motor.
The prop I used was fully balanced too.
As a result of the above I've taken to doing the same with my other engines.
I've also seen this suggested on other threads... but your results may vary.
Old 04-21-2010 | 10:32 PM
On glow engines you may find that the engine runs smoother when the heavy blade of the prop is aligned with the crankshaft counter balance.
Old 04-21-2010 | 11:14 PM
opjose's Avatar
ORIGINAL: HighPlains
Interesting... for my own edification, what is the logic behind this?
That the cylinder side is effectively heavier without the prop?
Old 04-21-2010 | 11:23 PM
Most engines (2C glow) could use additional counter balance weight. I seldom balance small props, but just determine if one blade is heavier with a very simple balance.
Old 04-21-2010 | 11:40 PM
JohnBuckner's Avatar
Dittos to what high plains said.[8D]
I can confirm possibly not exactly the same but with the small general aviation engine the Continental C-85 typical of Cubs, airnockers and Ercoupes etc. that there are six possible propellor/crankshaft orientations possible due to the bolt pattern. When the McCauley metal prop is used one of those positions there will be a very noticible vibration in flight and it can be eliminated simply by rotating the prop to any of the other five positions.
John
