 Pic's of inherited planes >
Old 05-17-2010 | 12:41 AM
Default Pic's of inherited planes
Ok, I got home with the planes. As it turns out, only two have engines and appear to be complete. Two more are built, but have no engines or controls, and one is still in the box. I'm going to post a few pic's and letyou guys tell me what to look for in order to identify and valus the planes and equipment. I'll start with the one of the complete ones:</p>
ID:	1437584   Click image for larger version
ID:	1437585   Click image for larger version
Old 05-17-2010 | 12:43 AM
Default RE: Pic's of inherited planes
Here's the other complete plane:
ID:	1437587   Click image for larger version
ID:	1437588   Click image for larger version
ID:	1437589   Click image for larger version
Old 05-17-2010 | 12:45 AM
Here are the controllers:
ID:	1437591   Click image for larger version
ID:	1437592   Click image for larger version
ID:	1437593   Click image for larger version
Old 05-17-2010 | 12:49 AM
And the unfinished:
ID:	1437595   Click image for larger version
Old 05-17-2010 | 12:50 AM
And finally, the new-in-the-box:
ID:	1437597   Click image for larger version
Old 05-17-2010 | 01:08 AM
These look to all be 40 size planes. Not a bad mix at all. The yellow one without engine is a Sig 4 star 40, a great second or third plane for the new guy. The orange one is a trainer of sorts. My guess is that it, then the 4* were #1 and #2 and the your first phots were #3 and #4 using the engines from #1 and #2. The Hots kit should gather a lot of attention. The starter and field box is good usable equipment. For a new guy into the hobby, this would be a great haul. You shouldn't have much trouble selling any of it. I am not familir with the radios, but they are at least a two or three levels back from the current ones. They won't fetch much as everyone wants 2.4ghz stuff now, but they are most likely still quite servicable and usable.
The trainer looks as if it has had a few rough landings, but isn't in that bad of shape based on the photos. The other planes look to be in OK to good condition. The one needs the cowl recut for the engine, it isn't going to cool well the way it is, but that is a minor issue. Good luck with them. They are a desirable set of planes. You shouldn't have much trouble selling any of them.
Don
Old 05-17-2010 | 06:31 AM
bingo field's Avatar
The orange one looks like an Ultra Sport. Still a very popular model. Too bad you are in Wa.
Old 05-17-2010 | 08:13 AM
MinnFlyer's Avatar
The red/yellow one is definitely an Ultra Sport - it's one of the best planes ever!
And I agree with Campgems, The trainer was probably his first plane, the 4-Star was his second and the two with radios was what he had advanced to
Old 05-17-2010 | 08:44 AM
My Feedback: (-1)
The Extra 300L looks like a fun little plane, the Ultra Sport is also a good one. The Hots kit is something I would like to have myself. Nothing there worth a bunch of money but the kit you may do OK on. The radios are worth next to nothing these days. I won't quote any prices because these are only worth what someone is willing to pay and the only thing I would want is the kit. I was getting my old kits at auction and never paid more then $20.00 for any of them and I know on the open market you can do a lot better then that.
Old 05-17-2010 | 09:11 AM
DenverJayhawk's Avatar
Don't the ailerons look small for an Extra? Definitely not intended for 3D.
Old 05-17-2010 | 09:41 AM
Thanks for the info and id's. What can you tell me about the engines in the first two? How are engines classified-by displacement or power or some other benchmark? I'd like to be able to speak somewhat intelligently when I go to sell them, and thanks to you folks, I may be able to do that!
Old 05-17-2010 | 10:05 AM
Minnreefer's Avatar
ORIGINAL: Jerryotis
You will probably need to take the cowling off the planes to see what the engine is exactly, they could be anywhere from an $15 engine to a $100 engine but without cleaning them up a bit they may not get much money.
Jon
Old 05-17-2010 | 10:28 AM
My Feedback: (8)
The yellow trainer looks like a recovered Tower Trainer.
Jim</p>
Old 05-17-2010 | 10:33 AM
oldvet70's Avatar
My Feedback: (10)
ORIGINAL: Jerryotis
A NIB Hots II sold for just over $100.00 at the Swap Meet in Grants Pass, Oregon in late March if that helps you any. Oh I see a Hots in the marketplace here ; http://www.rcuniverse.com/market/item.cfm?itemid=632274
Old 05-17-2010 | 11:13 AM
My Feedback: (13)
both of your engines are made by OS
the engine in the supersport looks like a 40-46 size and a little older since the needle valve in mounted in the carb, most of the newer models now have remote needle valve locations, look on the side of the engine case there is usually a logo which helps ID a engine type as well if its a LA version it drops the value a bit since it would be a bushed engine rather than having berings a somewhat important distinction for value judgments.
the engine in the extra is a little newer the cooling fins have a rounder shape to them which means its a fx (slightly older) but still a new generation engine.
if you pull the cowl off the extra it will help, hard to tell the size of it all covered up, the older engine could get between 50-75$ if it was cleaned up a bit, the newer one mabee a bit more depending on its size, larger means more worth.
too bad your not into the hobby you have a steady trainer to sport line up
Old 05-17-2010 | 11:31 AM
Very nice collection. Maybe i missed another thread but im just curious, was this inherited from your father? Do you just have no interest in trying to fly them?
Old 05-17-2010 | 12:18 PM
oldvet70's Avatar
My Feedback: (10)
ORIGINAL: fastandloud
http://www.rcuniverse.com/forum/m_9730011/tm.htm
Old 05-17-2010 | 05:25 PM
Fs one's Avatar
That extra 300L  kit is a house of balsa kit.It is a great flyer i totalled mine doing some fancy manuevers with it.Have always thought of building another.
Old 05-18-2010 | 08:11 AM
Mr67Stang's Avatar
I'd be interested in the Four Star if you are close enough for a local pick up? I have family in Sammamish, Wa. I am training my brother in law to fly this summer (June 16th) when I get up there and this would be a great second plane for him.
