 Double sided servo tape >
Old 05-31-2010 | 05:18 PM
Default Double sided servo tape
I have been salvaging parts from a wrecked Foamie and have a problem. I cut thru the D/S servo tape to get the Receiver off the plane. So far so good, but what is an easy way to get the tape off the Receiver ? slowgo
Old 05-31-2010 | 05:24 PM
Default RE: Double sided servo tape
Try dental floss.
Old 05-31-2010 | 06:54 PM
Peel most of it off then use "Goo Gone " to take the sticky goo off. You can get it at Wall Mart or most hardwares etc.. ENJOY !!! RED
Old 05-31-2010 | 09:20 PM
Charlie P.'s Avatar
Finger pressure pushing the foam/adhesive and scraping with fingernails. Oh, and a lot of patience.
Old 05-31-2010 | 09:24 PM
Goo Gone for sure. Clean up with rubbing alcohol.
Gary
Old 05-31-2010 | 10:17 PM
why bother?...gonna weigh you down?...Rog
Old 05-31-2010 | 10:50 PM
proptop's Avatar
My Feedback: (8)
I scrape it off with a finger nail, then use mineral spirits to remove the glue residue.
Old 06-01-2010 | 07:49 AM
bonebreak's Avatar
I have always used liquid lighter fluid (Zippo fluid) for all my sticky needs. It works much better than Goo Gone, and doesn't leave the greasy residue that Goo Gone does. It is super cheap too!
Old 06-02-2010 | 01:07 AM
repirazz's Avatar
Most servo tapes I've ever used will simply "roll" off if you rub it real hard with your thumb. Alcohol or brake cleaner on a paper towel for any remaining residue.
-rep
Old 06-02-2010 | 11:01 PM
tacx's Avatar
WD-40 works great. I have been using it for years. It removes sticker and tape type adhesives without damaging plastics.
Old 06-03-2010 | 02:00 AM
ORIGINAL: tacx
+1 /\ Better than goo gone. I would not use brake cleaner it may attack the plastic. follow up with alcohol.
Old 06-04-2010 | 11:14 AM
I use brake cleaner but you need to be very careful.
Old 06-04-2010 | 03:26 PM
TexasAirBoss's Avatar
My Feedback: (22)
razor blade and WD40.
