Reload this Page >
HiTec HS-325HB Servos on Trainer 60
Old 07-06-2010, 09:16 PM
winterdd
Default HiTec HS-325HB Servos on Trainer 60
I bought some Hi Tec HS-325HB servos.
The spec.says Applications: Aircraft 20 - 40.
Are they actually powerful enough on a Trainer 60?
It says Torgue: 51 oz. in at 6V, 41.6 oz-in at 4.8V
Old 07-06-2010, 09:30 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Default RE: HiTec HS-325HB Servos on Trainer 60
They will be just right - Enjoy
I have some myself
Old 07-06-2010, 09:31 PM
proptop
My Feedback: (8)
proptop's Avatar
They'll be ok...the trainer's control surfaces aren't all that large and the speed will not be what you'd call "excessive"...
Old 07-07-2010, 01:21 AM
winterdd
Thanks.
I was trying to install the servo onto the wing.
however, the servo is too tall and one end of it won't completely goes into the hole.
In other words, the wing is not thick enough.
You know, the wing is thicker on one side and goes thinner to the side close to Aile.
So, I could only screw down one side of the servo.
do I need to get some sort of servo mount tray?
or it is just a wrong size servo for my wing.
thanks again.
Old 07-07-2010, 05:09 AM
w8ye
My Feedback: (16)
w8ye's Avatar
The Trainer 60 should take standard size servos like the Hitec 325 without any adjustments other than a little trimming?
Are you sure there's not another piece of plywood spacer that goes there to raise the mount up higher?
Some of these planes, the servo pockets are a little small and you have to trim the pocket out a little for the servo to fit into the hole?
Old 07-07-2010, 11:53 AM
winterdd
I guess servo mounts are missing from the package.
I think I need to make a wood spacer to lift up the servo.
Old 07-07-2010, 01:00 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Should be item seven
