DX7 won't bind
TN
I'm having a little problem with the DX7 not binding with my AR7000. When the bind plug is plugged in the charge jack and I turn the switch on, both rx's will flash just once. I think it has to do with the charge jack. They dont look like the match up properly. What should I do? Do I need a special switch harness?
thanks
thanks
Try inserting the bind plug directly into the battery port: http://www.horizonhobby.com/ProdInfo...0UserGuide.pdf
TN
Thanks ya'll I got it.
I plugged the bind plug in the batt port and then plugged the batt in the throttle port. Thanks perreback for the link, I didnt get a user's guide when I bought the rx.
