prop / airplane question
FL
Going to maiden my u can do tomorrow I'm wondering if my prop pitch is OK. I'm running a 4 stroke with a 15x4 prop at 10,000 rpm. That's only 30 MPH max possible speed. Do you think that's enough speed? I wouldn't think it would knife edge that slow.
RE: prop / airplane question
It may help to know what size U Can Do as well as what size engine. I fly my 46 size with a 4 stroke 82 and a 13/7 pr op. and that seems fine for me.
My Feedback: (-1)
ORIGINAL: tripower222
1 Post
Hi!
I have a You-can-Do .60 too. Mine is powered by a 15cc (.91) two-stroke (MVVS 15cc). I have tried many props, 14x4W, 14x5N, 14x6, 15x4, 15x6 and 16x4 all APC and of the above props the 16x4 is the best.
Using a 15cc two-stroke engine in a You-can-do .60 is not going to give you a powerhouse but I can still climb straight up using full power.
My Feedback: (-1)
The maiden went well the 15x4 worked well but I think a 16x4 might be better its on a Saito 100 thanks for your input
