What's the Electric equivalent of OS 1.20
Hi,
Yes, there are many that will work.
All of these motors will need to operate on about 30 cells.
Good luck!
Good luck!
The decision often depends upon the model size and structure. The MEGAMax is also a direct drive solution so there is no gearbox involved and it can fit in some models better...again, depending upon the model.
I would use either the Sanyo CP2400SCR cells or the Sanyo HR-SC2600 NiMH cells.
Try giving Tom Cimato a call to discuss your needs at 716-662-5651. He can often clear up your questions.
You can also e-mail him here: MaxCim Motors
