Gary Wright gear drive problem. HELP!!
I just set up a Great Planes/Endoplasma gear drive with a 10 T pinion (MEC), and the spur gear was wiped out on the first test run. WHAT DID I DO WRONG? Please help.
Mike
Mike
RE: Gary Wright gear drive problem. HELP!!
Mike,
The gear mesh was probably too loose. Luckily, the gearboxes are inexepensive and you can buy replacement spur gears.
When I adjust mine, I listen for both noise reduction and current reduction using a variable power supply and no prop attached.
Although no grease is needed because the materials are dissimilar, a light Teflon grease application will help.
Good luck!
Good luck!
