Plain bushed Speed400 lubrication
Guy's
Any of you lubricate the end bell bushes of their Speed 400 motors (like Graupner 6V etc).
If so how often and what with ?
I've sort of done it from time to time but wonder if it was actually making it wear faster. I used 3in1.
Martin
Martin
RE: Plain bushed Speed400 lubrication
I use Dan's Banana Lube:
http://www2.towerhobbies.com/cgi-bin...&I=LXB804&P=ML
For can motors, I usually take 'em out every dozen flights or so, and spary out the brushes and inside the motor with motor cleaner spray, then lube the ends.
