x power esc
x power esc
bought a 50 amp brushless esc on ebay. came from hong kong. no instructions. can,t arm or program it.any sugestions. its an x power 50a high frequency digital esc. rated 12-18 cells or 4-6 li-po.
CA
RE: x power esc
XPOWER 50A
I hope it will be helpfull
Description :
- Weight : 33 grams / 1.15 oz
- Constant Current : 40A
- Max Current : 60A
- FET : 12 oz / 343 grams
- BEC : Yes, 5V/1A
- TIMING : Programmable - 2/7/15/30
- PWM : Programmable - 8K
- Input : 4 to 6 cell Li-Poly or 12/18 Ni-MH
- Low-Voltage Cutoff : Programmable
Features :
- Low resistence
- High rate PWM
- Sixteen cells Max (with BEC disabled)
- User programmable brake
- User programmable low-voltage cutuoff
- User programmable timing advance
- User programmable PWM
- Throttle range self-adjusting
- Soft start ramp up
- Runs motor in forward or reverse
- Auto motor cutoff with reset
- Safe power arming program ensures motor will not run accidentally after turn on
- Low torque start
- Auto shut down when signal is lost
Setup Memu
SETUP MENU ( for new 40A)
Type
Current
FET
BEC
Timing Mode
PWM
LI
NiHM
40-N
Normal: 40A
Max: 60A
12
5V/1A
2/7/15/30
8K
4 to 6
12/18
First, connect the motor and receiver to the speed controller
Remove battery power from the speed controller.
Turn on the transmitter.
Move throttle stick on full power position, (UP Position)
Reconnect battery power to the speed controller
After 3sec you can hear (all sound is 3times)
∮ — CELL Type AND Number
∮ — — BRAKE
∮ — — — TIMING MODE
ON you need programming menu, move the throttle stick to the middel position
1.CELL Type AND Number
• — NiMh/Nicd AUTO (0.8V/CELL*)
• — — 4LIPO (14.8V)
• — — — 5LIPO (18.5V)
• — — — — 6LIPO (22.2V)
* IF used 2LIPO you can use the option (select the NiMh/Nicd AUTO)
2. BRAKE
• • — NO
• • — — SOFT
• • — — — MID
• • — — — HARD
3. TIMING MODE
• • • — 2°
• • • — — 7°
• • • — — — 15°
• • • — — — — 30°
IF the option is you need, then move the throttle stick to UP position.
The long BEEP is save the option. and the system will go to the programming menu.
You can setup other options.
When all you need option is setup OK, push the throttle stick to down position, after 1sec the system were save all option, then you can start the motor now !!
Description :
- Max Current : 60A
- BEC : Yes, 5V/1A
Features :
- Low resistence
- High rate PWM
- Low torque start
Setup Memu
Type
Current
FET
BEC
Timing Mode
PWM
LI
NiHM
40-N
Normal: 40A
Max: 60A
12
5V/1A
2/7/15/30
8K
4 to 6
12/18
∮ — — BRAKE
∮ — — — TIMING MODE
• — — 4LIPO (14.8V)
2. BRAKE
• • — NO
• • — — SOFT
• • — — — MID
• • — — — HARD
3. TIMING MODE
• • • — 2°
• • • — — 7°
• • • — — — 15°
• • • — — — — 30°
