pinion gear question
Anyone know where I can get a 32 pitch 12 tooth metal pinion gear (perferably with a set screw) for a 2.3 mm shaft?
I have a pz P-51 and fw 190 that I want to go brushless on with the stock gearboxs but I dont want to use the stock plastic pinions ( they get spun on the stock brushed 480 motor ). I ordererd the metal gear from robinson racing but its for a 3.2 mm shaft. The real bummer so far is that I already orders the brushless motors with 2.3 mm shafts [&o]
TX
You might try Pete at http://www.modelelectronicscorp.com/ If he does not have them, he'll know who will.
Update. Pete didn't have it he did try to find one but turned up the same results I did. He gets an A++ in my book for trying to hunt one down. I'll make sure to check his site the next time I'm looking for parts
