Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
Stupid question
Old 02-20-2006, 01:57 AM
baldtrucker
Default Stupid question
I picked up my truck today and gave it throttle for about two seconds with the wheels off the ground to see if the tranny was shifting. . Did I do any damage to the motor? Or am I just being a hypocondriac with computer access?
Old 02-20-2006, 05:34 AM
snowbl!nd
snowbl!nd's Avatar
Default RE: Stupid question
A few seconds of the engine revving without a load won't have done any damage...
It revs without load when you jump it and try to bring the nose up anyway.
Old 02-20-2006, 05:36 AM
REVO 1
REVO 1's Avatar
Don't know if you have done any damage, If you only revved it a couple of times then probably not.
But you must Not do it again, you can cause damage to the engine revving it without any load on it (with the wheels off the ground)
Hope this helps!
Simon!
Old 02-20-2006, 06:30 AM
J_D
J_D's Avatar
all that damage without load its bull crap...
when i do jumps with mine you have to give it heaps of throttle to get it to back flip in the air... no dramas
Old 02-20-2006, 10:29 AM
smokingcrater
ORIGINAL: J_D
wait until your rod breaks.. running the engine above its specified rpm DOES stress the engine. it usually isn't one of those things that is all of a sudden, it is cumulative over time. one run out your engine suddently just quits if you are lucky, or has a hole punched out the side if you aren't.
Old 02-22-2006, 11:44 PM
ryan_t888
ryan_t888's Avatar
ORIGINAL: J_D
I partially agree to this. I over rev all of my engines, boat and car when they catch air at WOT. If a rod is going to go, there's no chance of saving it or anything. Also, if a rod goes how can you determine whether it failed due to over revving?
I believe you did not harm your engine from this one time incodent.
Ryan
Old 02-24-2006, 04:56 PM
markpc
Theoretically over revving a single cylinder 2 stroke cannot be done (within reason, reving 200,000 is well beyond capability)as long as the setup is okay and the engine is not going to overheat.
Oh yes quality counts too
