Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
Loctite
Old 02-28-2007 | 02:06 PM
Default Loctite
Bought a new cooling head for an O.S. Engine. When putting the screws back in do you use loctite (blue) to hold them in place?
Thanks.
Old 02-28-2007 | 02:58 PM
SManMTB's Avatar
Default RE: Loctite
No, there is no need for that.
Old 02-28-2007 | 03:52 PM
HeLLsGoD's Avatar
Default RE: Loctite
No, do NOT locktite engine head screws or else you will have problems taking them out again. Just do them tight enough and they will stay that way
Old 02-28-2007 | 07:38 PM
Default RE: Loctite
Be careful not to tighten them too much. The little 2.6mm screws used in an RG, and some others, don't have a lot of depth for the wrench to fit into, and strip out fairly easy. The last couple of rebuilds on my RG's, I had to remove the screws with a left hand drill bit.
Rotor
Old 02-28-2007 | 08:01 PM
hpi apollo's Avatar
Default RE: Loctite
use the star method to tighten them and leave them, they have a tendency to cook themselves in place
Old 04-04-2007 | 01:34 AM
Default RE: Loctite
DO NOT use any loctite or the screws will probably never come out again
Old 04-04-2007 | 05:24 AM
Riva32's Avatar
Default RE: Loctite
When engine is hot, loctite swoop down on screws
When engine is cold, screws will probably never come out
Thus do not use loctite on the engine!
Old 04-06-2007 | 03:25 PM
Default RE: Loctite
i fell like a dead cat
Old 04-15-2007 | 10:23 AM
Default RE: Loctite
whoever told u loctite kill them.....verry bad idea dude. [8D]
Old 04-15-2007 | 10:04 PM
j_blaze's Avatar
Default RE: Loctite
Don't over tighten either! the best thing to do is to tighten with the star pattern first then start her up. Check for smoke or fuel leaks around bottom of head, if so tighten the screw on the side of the leak some more, check for leaks again. Once head is straight and level with no leaks tighten all screws about 1/16-1/8 tighter and thats it. I strippeed out 2 screw holes and had to re-tap with the head turned 90 degrees, not fun.
