Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
Help
Old 05-23-2007 | 03:10 PM
Default Help
How do you know if your'e glow plug is burned out??
Old 05-23-2007 | 03:51 PM
hpi apollo's Avatar
Default RE: Help
you look at it, it will be broken and extremely thin, i think my glow plug guide could help a little
Old 05-23-2007 | 10:37 PM
Default RE: Help
Well i look at and it kinda looks burned in the bottom part, but i dont know if that's normal??
Old 05-23-2007 | 10:48 PM
hpi apollo's Avatar
Default RE: Help
define burned, pics are nice
Old 05-23-2007 | 11:00 PM
Default RE: Help
I know i wish i had a cam.. But it look's jus black on the bottom and there's a little tiny spring on the bottom of it..
Old 05-23-2007 | 11:38 PM
magnus213's Avatar
Default RE: Help
Test it. Hold it with pliers on the threads and plug the glow igniter into it. Mine (even the new ones) never glow all the way to the tip, but I'd estimate that you have maybe one coil between the very top and the bright, lit part.
Old 05-23-2007 | 11:50 PM
HeLLsGoD's Avatar
Default RE: Help
Their not supposed to glow all the way to the tip when testing. It only does that when its actually firing up inside the engine. If the element that sticks out is gray and intact and lighting up orangey/red then the plug should be fine.
Usually when your car is idling when you start it up and when you take out the igniter the revs change drastically, it either means your plug isnt in good condition or your plugs heat range is too cold for the engine
Old 05-24-2007 | 12:43 AM
Default RE: Help
No my car wont even start, i think it's because of this glow plug, that's my problem...
Old 05-24-2007 | 07:13 AM
hpi apollo's Avatar
Default RE: Help
well then do what we say, test it and see how well it glows, do that instead of saying "i think the glow plug is my problem"
Old 05-24-2007 | 02:00 PM
Default RE: Help
It doesnt glow at all..
Old 05-24-2007 | 03:46 PM
hpi apollo's Avatar
Default RE: Help
simple enough, now you should be able to find out what you need to do to fix it, we wont spoon feed you for every problem
Old 05-24-2007 | 07:20 PM
Default RE: Help
LoL i know, im just gonna buy a new one, and expect you guys to help my ass out for my other rc issues that i have... lol
Old 06-04-2007 | 03:06 AM
Default RE: Help
put the glow plug in your glow start and if the glow plug turns red it is good and if it does not turn red thene it is out.
thanks ,shelby
