Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
Pull start issue
Old 06-10-2007 | 08:18 PM
Default Pull start issue
Hi guys my cars pull start is way to easy to pull and the engine takes a long time to start up no matter how fast i pull it. and when i do get it finally started it runs fine and the lean and richness are set fine, so i have no idea what the problem could be, can u guys please help me.
Old 06-10-2007 | 08:31 PM
hpi apollo's Avatar
Default RE: Pull start issue
sounds like your engine is worn out, how old is it?
Old 06-11-2007 | 06:50 PM
j_blaze's Avatar
...or the one way bearing in the pull starter is dirty. If the engine is running fine I say its the bearing. Take it out and soak it with nitro cleaner, then wd40 then grease her up. Also clean the inside of the pull starer with nitro cleaner. Should start fine after that.
Old 06-11-2007 | 07:29 PM
hpi apollo's Avatar
yeah i didnt think of that, sometimes pull starts can accumulate oil in them and screw with the owb
Old 06-14-2007 | 11:47 AM
i noticed that when i opened up the opening behind the air filter that allows the engine to take in air allitle more than it would start up easier, but then when i started it it would start running instead of staying stationary.
Old 06-14-2007 | 11:48 AM
its not my engine i just got my car about a month ago.
Old 06-14-2007 | 11:49 AM
hpi apollo's Avatar
never run an engine without an air filter, ever
Old 06-14-2007 | 11:56 AM
yeh i know i didnt run it with the airfilter off .
