Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
Reading Glowplug
Old 06-18-2007 | 08:57 PM
REDisFASTER's Avatar
Default Reading Glowplug
Hi guys,
Just got a question for you guys on reading glow plugs.
First off, I'm running the AE .15X with 30% using an O.S. #8 plug. This apply to most engines, since its really more of a question on tuning, rather than the actual engine itself.
I've read some stuff about "reading your glow plug", but never really found an in-depth explanation of how to read it.
After a few tanks running my GT2, I notice that the first coil or two on the glow plug doesn't turn red-hot as the rest of the coils deeper inside. What is this telling me? What is causing this? What is the optimal look for a glow plug when the engine is properly tuned, and how would I need to tune my engine for the glow plug to read optimally?
Thanks in advance for your replies.
Old 06-18-2007 | 09:06 PM
HeLLsGoD's Avatar
Default RE: Reading Glowplug
The whole glow plug coil isnt supposed to glow, the only time the whole thing glows is when it is inside a fired up engine. The deep part should always be glowing orange/red color. The outside coil should always be intact and should look greyish and not distorted.
Dont you think os8 plug is a little too hot for 30%?
Old 06-18-2007 | 09:07 PM
That always happens to me on my picco .28 with the turbo plugs. i dont think nothing of it. it runs fine and idles all day with a great tune. I think my igniter was dead that why maybe.
Old 06-18-2007 | 09:15 PM
ORIGINAL: HeLLsGoD
Oh? Okay. I'll keep that in mind.
Also, what plug would you suggest for running 30%?
I noticed that when I started off using the stock glow plug that came with the GT2 RTR and ran 10%. I moved tp the OS#8 and ran 30% and it seems that a tank of fuel lasts at least 6-8 minutes longer (roughly 10-15 minutes on a tank), versus the 5-6 minutes on 10%.
Old 06-18-2007 | 10:01 PM
HeLLsGoD's Avatar
oh i see i see
Usually running high nitro requires a cooler plug. You might be able to pull out a little more power and engine consistency with a colder plug
heres a short guide from os:
[link]http://www.osengines.com/accys/glowplugs.html[/link]
[link]http://www.osengines.com/accys/choosing-glowplugs.html[/link]
Old 06-18-2007 | 10:05 PM
Ah, okay okay. Would you recommend the A5 plug then?
Old 06-18-2007 | 10:10 PM
aer-wubby's Avatar
Here's a nice visual explanation;
Old 06-18-2007 | 10:26 PM
Ah, I guess I'm running slightly lean! Not too much that it'll be that bad for my engine. Richen it by 1-hour and give it a go tomorrow!
Old 06-19-2007 | 08:50 PM
Aer-wubby:
where did you find that glow plug article? The photo and captions are not entirely accurate in the explination.
Old 06-19-2007 | 09:33 PM
ORIGINAL: Fuelman
Aer-wubby:
Judging by the font, I'd say its from RCCA
