engine help
so today I am trying to tune my os.12 cv engine in my xxx-nt. It has been 8 months. so I start it up, I try to get it running right, and no luck. when I start it up and warm up Put it on the ground and try to take off it revs up and slowly takes off, so I adjust the slipper 1/4 turn, and put it back on the ground and it dies. and also when I am driving it and I hit the brakes it kills the motor. Any help would be great.
Thanks.
Thanks.
Pull the carb and clean/flush it well including all the needles. Use new o-rings when reassembling. Reset all needles to factory settings including the idle gap. Reinstall it. Verify that the linkages are set up right. Install a new glow plug. Start it and tune as normal.
Oh yeah, and tighten the slipper all the way down and back it off 1/8 - 1/4 turn. You may need to check the slipper friction material to be sure it's still good.
