Question about ports on Force .28
I took apart my Force .28 5 port in my CRT RTR to do some port work and I found that the sleeve was already completely ported. Is this how they come from the factory?
RE: Question about ports on Force .28
ORIGINAL: Nitro Bill
Alwasy remember thoughs, these cuts contibute very little to increasing performance. It is the timing profile and choosing a pipe to match the timing profile that determines performance output.
ORIGINAL: SAVAGEJIM
If you mean that there are flow channels milled into the sleeve, the crank has a turbo cut into it, etc., then, yes, as far as those go, those "mods" came like that from the factory.
